Nebula FWA515: firewall can be deactivated?
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited December 2025 in Mobile Broadband
Hello everyone,
I have to buy some FWA515 to optimize mobile connectivity on remote sites.
I went on spec page:
https://www.zyxel.com/it/it/products/mobile-broadband/nebula-5g-be7200-indoor-router-nebula-fwa515/specifications
But it is not written if the internal firewall could be deactivated:
I would like to deactivate it to avoid interference and establish a VPN full tunnel from remote using IP passthrough.
    PeterUK Posts: 4,411 image  Guru Member
    I wouldn’t think it be a problem I have the FWA510 in IP passthrough that connect to VPN tunnels outbound not all ISP give you a WAN IP for inbound and are CGNAT which only allow outbound.
    If you look on page 274 you can disable the firewall if needed
    https://download.zyxel.com/Nebula_FWA515/user_guide/Nebula%20FWA515-UG.pdf
  • GiuseppeR
    That's great, I only read the specs and not the manual.
    I placed them in the shopping cart 😎
