Nebula FWA515: firewall can be deactivated?
GiuseppeR
Hello everyone,
I have to buy some FWA515 to optimize mobile connectivity on remote sites.
I went on spec page:
But it is not written if the internal firewall could be deactivated:
I would like to deactivate it to avoid interference and establish a VPN full tunnel from remote using IP passthrough.
I wouldn’t think it be a problem I have the FWA510 in IP passthrough that connect to VPN tunnels outbound not all ISP give you a WAN IP for inbound and are CGNAT which only allow outbound.
If you look on page 274 you can disable the firewall if needed
https://download.zyxel.com/Nebula_FWA515/user_guide/Nebula%20FWA515-UG.pdf0 -
That's great, I only read the specs and not the manual.
I placed them in the shopping cart 😎
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
