DX3301 router - Need to use own certificate for https access to prevent browser error messages.
Like many others, I am frustrated by browser security warnings when I log on to my Zyxel router. I am seeking to replace use of the default Zyxel cert used by the DX3301 router for https logons to its GUI pages by my own, self-signed but trusted certificate. I have created the certificate, and successfully imported it to the DX3301's Local Certificates, but I can not find where to tell the router to use that particular certificate for https access to the router, which continues to use the default Zyxel certificate. Can anyone help?
Me too
Hi VicSavy,
What you want to do might not be possible, unless you request a new certificate that will be signed by Zyxel's CA.
See below user manual extract from the DX3301 user manual dated 2022.
Happy New Year.
Regards, Tony
I am able to do everything that is required, including creating my CA, and importing a trusted certificate into the router. But I am stuck at the stage of how to tell the router to use the specific new trusted certificate that I have imported for web/ssl access. Some Zyxel routers seem to have a menu option like "SSL VPN", "General Setup" that allow you to Replace the default HTTPS and SSL Certificate, but I can't see anything similar on the Zyxel DX3301-T0 router. Does anyone know how one does that on this particular router?
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
