Has Someone Firmware Ver.V5.21(ABAG.15)_myZyXELCloud-Agent_0106
ReconnectICT
ReconnectICT Posts: 8 image  Freshman Member
Hello All
Can someone help me to find/download firmware version
maybe if i have that i can get my NAS back online, i get the impression that nothing else will work.
Thanks a lot in advance
Paul Moolenaar
  • Mijzelf
    Mijzelf Posts: 3,023 image  Guru Member
    You want this in a single package? AFAIK there doesn't exist something like V5.21(ABAG.15)_myZyXELCloud-Agent_0106. V5.21(ABAG.15) is a firmware, myZyXELCloud-Agent_0106 is an installable package.
    Here you can find 5.21(ABAG.15), and myZyXELCloud-Agent_0106 can still be found on the package server, ftp://ftp2.zyxel.com/NAS542/zypkg/5.21/
  • Mijzelf
  • ReconnectICT
    hello Guru Member,
    Thanks for your response i think this is just what i ment,
    Little question do i need username and paswoord for the ftp site?
    Thanks in advance
    Paul Moolenaar
  • Mijzelf
    Depends on your client. The server supports anonymous login, which is default for many clients. But if the client doesn't support it, the credentials are anonymous,a@b.c , or any other e-mail address.
  • tronka
    tronka Posts: 2 image  Freshman Member
    In this page you have the official firmware at the lastest version
    https://www.zyxel.com/global/en/support/end-of-life
