ATP200 - Impossible to adopt it in Nebula
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited January 7 in Nebula
Hello everyone,
I justs unboxed a brand new ATP200.
So I went on its 192.168.1.1 to update its firmware and I downloaded it from Zyxel repo.
Then I went again on that page to configure it and I am not able to adopt it via Nebula.
Neither via USB (formatted in FAT and FAT32) via json file.
Neither resetting it.
If I try to login now I see:
Anyway if I go via Nebula I see this error:
No green button.
Could be possible that there is a conflict on this site because here I have a security router before?
Please give me some ideas… 😎
  • Zyxel_Barry
    Zyxel_Barry Posts: 120 image  Zyxel Community Virtual Assistant
    Hi @GiuseppeR,
    It appears you're encountering difficulties adopting your new ATP200 into Nebula, with "Login denied" on the local interface and an error during the deployment method in Nebula. This typically indicates the device is either already managed by Nebula or is attempting to enter a Nebula-managed state where local credentials are superseded.
    Here's a step-by-step guide to troubleshoot and resolve this:
    1. Perform a Factory Reset: Since you've just unboxed the device, a thorough factory reset can help clear any lingering configurations. Press and hold the RESET button on the front panel of the ATP200 for at least 10-15 seconds until the SYS LED flashes. Release the button and allow the device to reboot. This ensures the device is in a clean state before Nebula adoption.
    2. Verify Firmware Version (Downgrade if Necessary): Some firmware versions (e.g., 5.37 P1, 5.37 P2, or 5.38) removed ZTP mode, requiring a downgrade to 5.37 P0 for ZTP deployment. If your ATP200's serial number doesn't start with S23xxxxxxxxxx or S24xxxxxxxxxx, you may need to downgrade the firmware to 5.37 P0 (ABFW.0) before proceeding with Nebula adoption. You can check the firmware version via the local GUI after the reset.
    3. Use Nebula Native Mode (if applicable): If your device's serial number is S23xxxxxxxxxx or S24xxxxxxxxxx, it should support Nebula Native Mode for deployment. In Nebula Control Center, when adding the device, select "Nebula native mode" instead of ZTP.
    4. Check Nebula Site-Wide Password: The "Login denied" message with "This device is managed by Nebula" indicates that the local login credentials have been overridden by Nebula's site-wide password. If the device successfully joins Nebula, you'll need to use the password found in Nebula Control Center under Site-wide > Configure > Site settings > Device configuration > Local credentials > Password to access the local GUI.
    To further assist you, please provide the following information:
    • The full firmware version currently running on your ATP200.
    • The first 5 characters of your ATP200's serial number.
    • A screenshot of the "Deployment Method" page in Nebula showing the exact error message and what options are greyed out, if any.
    • Your Nebula Organization and Site name. To allow our support team to investigate directly, please enable Zyxel Support Access through Help > Support Request in your Nebula control panel.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,538 image  Zyxel Employee
    Hi @GiuseppeR
    It seems like the device change to Nebula mode, but Nebula shows it is offline and/or ZTP is not finished.
    May I know the org/site name and enable the support privilege so we can check this further?
    Zyxel Melen
  • GiuseppeR
    edited January 7
    Hi @Zyxel_Barry
    let me give you the answers.
    1. done, with no results. I always tried the Nebula native mode after updating the firewall to 5.41
    2. I have 5.41 onboard, I cannot downgrade to 5.37 as you said (my serial is S222L4xxxxxxx) because Portal Zyxel does not give me this option
    3. done, all the times since the first boot (also because I need to deploy it via Nebula)
    4. checked, copied from Nebula NOT working on premise
    Portal Zyxel:
    Support page:
  • GiuseppeR
    edited January 7
    Hi @Zyxel_Melen
    sent you a PM with details and priviledges, I'm at your disposal.
    I see right now that Barry is an AI 😎
  • Zyxel_Melen
    Hi @GiuseppeR
    Since your device S/N shows it is an old device(by manufacture year), please try to downgrade to 5.37 patch 0(firmware file sent by private message) and start the ZTP process again.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I can confirm this working path:
    • reset
    • enter the firewall in On-Prem mode
    • flash partition 1 with 5.37
    • automatic reboot
    • flash partition 2
    • automatic reboot
    • login to check both are 5.37
    • reset
    • login to 192.168.1.1 and then select Nebula mode
    • click on ZTP on Nebula Page
    • plugin the pendrive with json
    Adopted on Nebula:
Nebula Tips & Tricks
