How get supervisor od root password of NR7103 modem?
14567810»
  • Staman
    Staman Posts: 3 image  Freshman Member
    Is there anyone who can help?
    The device is running a modified O2 Slovakia firmware, and we are unable to access the Web UI (not even the user login). SSH is enabled, but it shows the same behavior — login is not possible.
    Can someone advise whether such a device can be flashed using ZyCAST with the Zyxel factory firmware V1.00(ACCZ.1)C0?
    Please, if anyone knows, many people would be very grateful.
  • luckyjoe
    luckyjoe Posts: 2 image  Freshman Member
    I have reseted the NR7302 and now I do not have the password. Can you please tell me the default password for SN: S240Z19005493
    Thank you
  • estornudo
    estornudo Posts: 3 image  Freshman Member
    Hello I have a AX7501-B0 with serial S210Y52056631 and I'm unable to login to it.
    Can I please have the supervisor/admin account?
    Thank you!
  • estornudo
    Hello I have an AX7501-B0 with serial S210Y52056631 and I'm unable to loginCould I please have the supervisor/admin/root password?Thank you!
