[NEBULA] Setup easy VPN connection to a NSG50
Hi there,
Can i find a manual somewhere, how i can setup a NSG50 as a VPN server?
My situation: a NSG50 is in the DMZ of a NAT gateway.
In the NSG50 i made several VLAN, i would like for clients to be able to connect to one of the VLAN with their laptop so they can access local devices (a NAS) in that network.
I was not able to find a quick solotion how i could make this work, if someone could give me a hint :)
gr. Bram
Best Answers
Hi Bram, I guess you need to set up the L2TP VPN, you could check this:
You could use the cloud authentication for authentication instead of the Radius as explained in the link.
"You will never walk along"5 -
Hi Bram,
NSG cannot specify VPN role In current stage, however like RUnglaube points out you can still use L2TP over IPsec VPN as the solution.😊
Chris
5
Hi @Alfonso, thanks for the quick response!
I already saw the link you provided, but that's not what i mean.
As i understand it correct, the tutorial in the link describes how to make the NSG client of another VPN server.
I am looking for the other way around. I want the NSG to be my VPN server, where i can connect to (with windows-native-vpn setup or a client vpn tool or something like that).
In a lot of routers i am familiar with, i can easy setup a VPN server in the router, on the devices you want to connect you simply install a client (exampl. OpenVPN client-app or something like that).
Perhaps i'm looking at it all wrong, i would like to connect (with a windows-laptop/tablet/smartphone) to the LAN network behind the NSG to acces a NAS and other machines.
Perhaps there is not such a functionality (yet) in the NSG's, then i have to find another solution.
Thanks for your time and help.
gr. Bram
HI @Bram_Lortye
Obviously it can be done with NSG.
I recommend to configure an IPSEC L2TP server, because most of devices can establish that kind of VPN.
A "how to" can be found at:
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=016271&lang=EN
Regards
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
