Unable to split the Network
Hello. I Can´t split the Wireless Lan Networks in 2.4 G and 5 Ghz, the checkbox is greyed out.
My backup File is attached below.
Greetings
Marcel N
Hi @Marcel_N,
Thank you for the update. The issue where you can't split the 2.4 GHz and 5 GHz Wireless LAN networks in v1.60 (with the checkbox greyed out) is likely due to the configuration not being fully imported at the time.
Please try upgrading again—this should allow you to disable “Keep 2.4G and 5G the same" option.
Let us know if it works or if you need further assistance!
Zyxel Tina
Hi @Marcel_N,
I understand you're experiencing an issue where the option to split your 2.4 GHz and 5 GHz Wireless LAN networks is greyed out on your Zyxel Mobile Broadband device.
This typically happens when certain features like Mesh or MLO (Multi-Link Operation) are enabled, as they often require a combined SSID for both bands.
To help resolve this, please provide the following information:
- Device Model: Please specify the exact model of your Zyxel Mobile Broadband device.
- Firmware Version: The current firmware version running on your device.
- Screenshots: If possible, provide screenshots of the "Wireless" or "Wi-Fi Settings" page where the checkbox is greyed out. This will help us understand the context.
- Network Topology: A simple diagram of your network setup, if applicable.
If your device is managed by Zyxel Nebula, please enable Zyxel Support Access to allow our team to view your cloud environment configuration directly. This can significantly shorten troubleshooting time.
- Go to
Help > Support Requestin your Nebula console. - Enable "Invite Zyxel support as administrator" and set the expiration days.
- Provide your Organization name and Site name.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Thanks for the answer.
After i purchased my FWA515, i Upgraded the Firmware to 1.60(ACPZ.0)CO. This was the latest Firmware to downoad on the 515 Download Page. After posting my request for help, i decided to roll back to 1.50(ACPZ.0)CO. This fixed my Problem and i am now able to split Networks. Under 1.60 i was even unable wwhen i disabled MLO in W-Lan Settings because the Page said something about disable Mesh,but i was unable to find the the settings for that. For now, my Problem is solved.
My Device Model is the Nebula FWA 515
Greetings
Marcel N.
Hi @Marcel_N,
Zyxel Tina
Hello @Zyxel_Tina ,
I Upgraded the Firmware to 1.60, selected Restore Factory settings and after a Router Restart, i am able to split Networks again.
Seems like that have solved my Problem.
Thank you very much for the help.
Greetings
Marcel N.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
