Unable to create a mesh router with the Zyxel EX3501-T0 router
PuebloFresco
PuebloFresco Posts: 2 image  Freshman Member
I'm trying to connect the Cudy WR3000 router via mesh with the Zyxel EX3501-T0 router from the internet company digimobil.es (Spain). Both routers are compatible with EasyMesh.
I've configured the Cudy router as the primary router. I've reset the Zyxel router. I've tried creating the mesh by pressing the WPS button on both routers.
The mesh isn't created.I've called digimovil.es, and they tell me they can't provide support with the mesh.
Could it be that the Zyxel EX3501-T0 router isn't compatible with EasyMesh?
Does the Zyxel EX3501-T0 router need a firmware update?
Do you know what the problem could be?
  • CryBananaCat
    CryBananaCat Posts: 63 image  Ally Member
    Although EasyMesh is an industry standard, the implementation and versioning (e.g., R1, R2, or R3) can vary significantly between different manufacturers.
    Specifically, routers provided by ISPs often use customized firmware that may restrict the device's role within a Mesh architecture—for instance, locking it as a Controller only. This often leads to compatibility issues during the auto-pairing process with third-party devices (such as Cudy). Therefore, establishing a Mesh network between different brands is not guaranteed to succeed.
