Nebula 19.30 unable to update a Flex 200H with 1.37
GiuseppeR
GiuseppeR Posts: 686 image  Guru Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
this night at 02.00 was planned an update to a 200H to 1.37.
Right now I still see the alert:
about the update that should have been done, but the firewall is still at 1.36:
Have I to update it manually via local UI?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,681 image  Zyxel Employee
    Hi @GiuseppeR
    Please help to enable zyxel support access and share org's name for us to identify this issue.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I have the same issue also with 50Hs, same planned update the past night…:
    Sent a PM with these ORGs.
  • Zyxel_Melen
    Hi @GiuseppeR
    After checking, this is because our team postponed the auto firmware upgrade date before your scheduled job start, which is because we will release a new patch this month. Since we want to avoid firmware upgrades many times in a short time, we postponed.
    If you want to upgrade first, you may process the upgrade now.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    is this valid for all the H series?
  • Zyxel_Melen
    Hi @GiuseppeR
    Yes, since all H series will have a patch.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    I see this post:
    Is this the patch that you were mentioning?
    So now I can manually update all my H series' firewalls?
  • GiuseppeR
    Hello everyone,
    when forcing the update from Nebula, not all the H series firewalls go for the update:
    So I used also Nebula App to push the update.
    No positive results for all the devices I was "Upgrading" looking at the Nebula web UI.
    As you can see this one:
    Needed a manual reboot before the update to 1.37:
    As you can see on Nebula there is the wrong timestamp for the last update (that timestamp is the last attempt made via Nebula App with NO success…):
    Then I went to the Nebula area where to push the update:
    And then FINALLY I have the firewall updated:
    How can I solve all these issues when upgrading?
  • Zyxel_Melen
    Hi @GiuseppeR
    No, the firmware I mentioned is V1.37 patch1.
    About the firmware upgrade issue you encountered, I have checked the event log, which shows "[Nebula] Automatic firmware update was unsuccessful. Please reboot the device first,….". This issue is more likely due to the firewall not having enough storage to hold the firmware file and process the firmware upgrade. Rebooting the firewall can help clear the temp and free up storage.
    Zyxel Melen
  • GiuseppeR
    edited February 26
    Hi @Zyxel_Melen
    I see this issue (reboot before upgrade) more often lately.
    It happened for various items from H series to budget routers like SCR50AXE (last time on 2026-02-24 19:27:22) that I tried to update. I understood that because I saw the upgrade failing, then I reboot, then I upgrade the hardware and then the job was done.
    It is time consuming and frustrating because it is an operation you cannot schedule.
    Considering the fact that on some ORGs there is an automatic update schedule and considering that when you press the button for the upgrade on Nebula you know you want that upgrade…. could be possible to set Nebula to make quick tests if there is enough room to complete the update and, if not, run an automatic reboot with automatic upgrade without asking the MSP to wait for all those actions?
    Also because doing these steps during night time could be useful and not frustrating instead of doing that calling the Client, stop the office and accomplish that maintenance operation during office time because you are forced to do it manually.
Nebula Tips & Tricks
