Router mode Nebula FWA505
oussi
oussi Posts: 2 image  Freshman Member
Hi everyone
I bought a Zyxel NR7302 and installed it; it works fine. I connected it to a Nebula FWA505 with the cable and set it up as a router. However, after doing this, I can no longer access the web login address on NR7302 (I changed the login address). Although I tried other routers and they worked normally, I think the problem is with the Nebula FWA505. I hope you can suggest a solution for me. Thank you.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @oussi
    To clarify this, please share:
    1. What IP is your NR7302?
    2. What DHCP IP range is your FWA505?
    3. What IP is your PC/laptop using when having this issue?
    Zyxel Melen
