XGS1930 and MAC filtering on a port
Venta
Venta Posts: 11 image  Freshman Member
Hallo,
can someone help me if XGS1930 does support MAC filtering on a port, so only a LIST of supported MAC are allowed on this port to connect?
If it is supported, how can i configure it and is configuration also possible over Nebula?
Wolfgang
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Venta
    MAC filter is a list of MAC that been blocked. It is not an allowed list for switch.
    May you share your scenario so we can help to find a solution?
    Zyxel Melen
  • Venta
    My idea: I have a port configured for a special VLAN which have a lot of rights assigned on the firewall based on the VLAN.
    So the idea was to restrict access on this special port to only some MAC-Addresses.
    Any idea how to do this?
  • Zyxel_Melen
    Hi @Venta
    For this purpose, you need to configure via device's local GUI since it is not supported on Nebula control center.
    Here are the steps:
    1. Upgrade your XGS1930 to V5.00 firmware version.
    2. Finish other configurations on Nebula first.
    3. Access device local GUI to configure port security & Static MAC Forwarding.
      1. Set port security:
        Path: Menu > Security > port security.
        1. Activate port security.
        2. Activate port security for specific port(s).
        3. Inactivate address learning.
        4. Limited number of learned MAC address needs to be 0.
      2. Set static MAC forwarding:
        Path: Menu > Switching > Static MAC Forwarding.
        1. Click Add/Edit button to add the MAC address.
        2. Enter the MAC address and other value.
        3. Click apply button.
    Note:
    1. The configuration that edited/configured from device's local GUI will not sync to Nebula.
    2. Change configuration on Nebula might cause these configurations been overwritten.
    3. Local device's local GUI requires to use your site's local credential. Please reference this FAQ to find it.
    Hope this helps.
    Zyxel Melen
  • Venta
    Thank you so much.
    Is there any plan when this option is also available via Nebula?
  • Zyxel_Melen
    edited March 11
    Hi @Venta
    We do have a topic for this, but we currently don't have an ETA.
    Additionally, I have created an idea post to monitor the requirements on this function:
    Restrict access on this special switch port to only some MAC-Addresses on Nebula — Zyxel Community
    We will monitor the comments and votes of this link the evaluate it.
    Zyxel Melen
Nebula Tips & Tricks
