FWA515 Wireguard VPN Configuration
m0p0h
m0p0h Posts: 3 image  Freshman Member
Hi.
I've migrated to FWA515 device from a Fritzbox. On the fritzbox I could set up a Wireguard VPN from a configuration file created from my Windscribe account.
I don't see any config settings like this on the FWA515 settings in either Nebula or the device settings or the remote msnagrment. Where in Nebula or on the device settings do I configure a VPN?
    PeterUK Posts: 4,451 image  Guru Member
    edited February 12
    I think none of Zyxel products support Wireguard VPN as a server or client also the FWA515 has no VPN server or client option.
  • m0p0h
    Thanks for reply. Sheesh that's not good news. I've just spent a small fortune on this device & it doesn't support basic VPN support that's available on the device it's replacing. There's also a subscription which isn't described anywhere before you purchase but pops up when you go to configure it.
  • Zyxel_Tina
    Zyxel_Tina Posts: 724 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @m0p0h,
    Thank you for your feedback. To clarify your concerns:
    • VPN Capabilities: The FWA515 is primarily designed as a 5G mobile router that supports IP Passthrough to allow VPN traffic through. However, it does not feature built-in VPN Client/Server capabilities (such as WireGuard or OpenVPN). Currently, Tailscale VPN (a third-party VPN service built on the WireGuard protocol) is supported on our USG FLEX H-series firewalls.
    • Subscription Inquiry: Regarding the subscription you mentioned, could you please provide the name of the service and a screenshot where it appeared? This will help us identify the problem and assist you further.
    Zyxel Tina
