1.37 uOS - Nebula SSL VPN - Change from Cloud Authentication to Local Users
Hello everyone,
following this thread:
I saw that upgrading from 1.36 to 1.37 the Nebula UI shows me changed authentication from "Nebula cloud authenticaton" to "Local Users".
I re-use same screenshots taken for the above thread so do NOT look at the arrows but the "Sign-on with"…
—> 1.36 online config
—> 1.37 online config
Does that happen only to my setup?
Anyone else sees the same changing?
I haven't seen this in our setups.
Did you perhaps have Local users selected on the local USG GUI prior to the firmware update, and after the firmware update reboot, this local config has synchronised to Nebula?
The download option being grey in the first photo would indicate that the USG had a 'Not up to date' configuration status on the Nebula side before updating to uOS 1.37.
Well… I'm sure at 99% about to have NOT modified parameters but perfection is not mine and for this reason I checked here on the forum… I remember that I had rebooted the H series manually because it did not cooperate properly when I pushed the update from Nebula.
So I'm pretty sure this was the only operation I did via local UI.
It is really strange for us to see "Local Users" because we usually set "Nebula Cloud Auth" to let users setup their 2FA and other infos autonomously
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
