BPDU block on edge and mac-limit
jonashauge
jonashauge Posts: 1 image  Freshman Member
edited April 2021 in Nebula
it would be a great addition making it possible to block/shutdown edge switchports if a spanning-tree BPDU is seen or number of mac addresses raises over a certain level.
The background for this request is to limit users from installing third party switches which can break your topology.
Bonus would be to do spanning-tree root guard as well.
Overall that would raise the enterprise capability of the products quite significantly.
  • Zyxel_Jason
    Zyxel_Jason Posts: 432
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    Hi @jonashauge ,
    Welcome to Zyxel Community!
    From your description, I think you are talking about the BPDU guard which we have already had the feature that you may configure on NCC.
    You may go to "SWITCH > Configure > Switch ports > (Choose ports) > STP guard" to configure.
    Hope it helps.
    Jason
Nebula Tips & Tricks
