removing unknown nebula account?
riccy
riccy Posts: 8 image  Freshman Member
HI
New to these discussions.
I recently bought a secondhand Zyxel fwa710 off ebay.
it appears it is locked to a (unknown ) Nebula account?
I stumbled across a post recently, where it says Zyxel support might be able to help with this.
Happy to provide proof of the purchase.
Many Thanks for any help in advance.
Riccy
  • Sandro_ACP
    Sandro_ACP Posts: 8 image  Freshman Member
    Use the nebula app on your smartphone (it has to be the app on the smartphone!) linked to your Nebula account add the qrcode on the device from there.
    I do it all the time with used devices from Amazon and it works like a charm.
  • riccy
    Hi Sandro
    Thanks for the reply- appreciated.
    I've only ever used these in standalone mode, so do I need to register for the nebula app, and then scan the device Qr code?
    Is ii that easy?
    Many thanks
    Riccy
  • GiuseppeR
    GiuseppeR Posts: 686 image  Guru Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    Hi @riccy
    you can scan it as said by @Sandro_ACP with the Nebula App and adopt it inside your Nebula ORGs.
    Only if the previous owner locked its adoption you will NOT be able to adopt it.
  • Zyxel_Tina
    Zyxel_Tina Posts: 725 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @riccy,
    As suggested by Sandro_ACP and GiuseppeR, you may also refer to this article for clearer instructions on installing the app, creating an org/site, and registering your FWA710 under your account.
    Additionally, please note that the Nebula mobile app provides basic monitoring features only for FWA (mobile router) devices. For advanced settings requirements (cellular-related functions, WiFi SSID, etc.), please log in directly to the device's local GUI to perform the necessary configuration.
    If you encounter a situation where the previous owner has locked the device to prevent others from overriding the ownership, feel free to let us know. In this case, please provide your proof of purchase (receipt/invoice) and a photo of the label (showing the device's S/N and MAC) via private message so we can assist further.
    Zyxel Tina
Nebula Tips & Tricks
