How get supervisor od root password of NR7103 modem?
Is there anyone who can help?
The device is running a modified O2 Slovakia firmware, and we are unable to access the Web UI (not even the user login). SSH is enabled, but it shows the same behavior — login is not possible.
Can someone advise whether such a device can be flashed using ZyCAST with the Zyxel factory firmware V1.00(ACCZ.1)C0?
Please, if anyone knows, many people would be very grateful.
I have reseted the NR7302 and now I do not have the password. Can you please tell me the default password for SN: S240Z19005493
Thank you
Hello I have a AX7501-B0 with serial S210Y52056631 and I'm unable to login to it.
Can I please have the supervisor/admin account?
Thank you!0 -
Hello I have an AX7501-B0 with serial S210Y52056631 and I'm unable to loginCould I please have the supervisor/admin/root password?Thank you!
If you’ve lost the sticker with the default password, there isn’t a supported way to generate the supervisor/root password from the serial number. That information isn’t publicly available for security reasons. Your best option is to do a full factory reset using the reset button on the device (usually hold it for about 10–15 seconds while powered on). After that, the modem should revert to its default login credentials, which are typically printed on the label, if that label is gone, you’ll need to contact Zyxel support directly with proof of ownership. They can guide you on the proper recovery steps. Definitely don’t throw it away yet, a factory reset or support ticket should sort it out.
did you ever try this ?
how would you open a support ticket for a nr7302 ?0 -
Hi, I have resetted NR7303 from O2 Slovakia. But I dont have password admin nor superviser, can you please provide? There is no password on box or device. SN: S240Z12001225
Hi, I have resetted NR7303 from O2 Slovakia. But I dont have password admin nor superviser, can you please provide? There is no password on box or device. SN:S240Z34009173
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
