Are there any antenna differences between the four T9 connector on FWA510?
If the answer is No then why four and not only two or one?
Hi @Finnsvenning,
Regarding your question, there are no functional differences among the four TS9 connectors. As the FWA510 supports 4x4 MIMO technology, it allows four simultaneous data streams via four transmit/receive paths, resulting in higher throughput and better connection reliability.
Therefore, we recommend connecting antennas to all four ports to ensure you get the maximum performance.
Zyxel Tina
Hi @Finnsvenning,
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
