About WAN DNS on USG LITE 60AX
Arthur
Arthur Posts: 2 image  Freshman Member
In the monitor section of Nebula, for my USG LITE 60AX router, I see the WAN status showing the IP address from my ISP, the connection type (PPoE), a gateway IP address, and two DNS server IPs. But the latter two differ from what I set in the LAN settings, namely 8.8.8.8 and 8.8.4.4. It seems to me these DNS IP addresses are ISP DNS servers, but shouldn't these be overridden by the Google ones?
And if so, how do I do that? I cannot find any settings. In the community, I found information on setting the FQDN, but it lacks details, so I have no idea what the whole point is, even though it refers to WAN DNS.
  • GiuseppeR
    GiuseppeR Posts: 686 image  Guru Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    On my Lite 60s the WAN interface does not let you declare the DNS from PPPoE connection (only VLAN and connectivity check):
    For this reason I use to declare custom DNS via LAN, to let that specific LAN/VLAN to know where to resolve DNS addresses
  • Zyxel_Tina
    Zyxel_Tina Posts: 727 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Arthur,
    As GiuseppeR mentioned and recommended, the USG LITE 60AX does not support manually setting up WAN DNS. The DNS servers shown in the WAN status are typically assigned by your ISP.If you would like to manage DNS settings for your LAN clients, please navigate to:
    1. Site-wide > Configure > Security router > Interface
    2. Click "Edit" on your LAN interface.
    3. Set your desired DNS servers (e.g., 8.8.8.8 and 8.8.4.4) for the LAN interface.
    This will ensure that devices connected to your LAN use these DNS servers.
    Zyxel Tina
Nebula Tips & Tricks
