NSA325-v2 - Issues installing Entware-ng repository - install SMB v2
Hi all,
On my NSA325-v2 NAS I have successfully (re)installed the Mijzelf Meta Repository. I can see all the packages from both (fw4_stock and fw4) repositories listed.
Now I am trying to install the Entware-ng repository. My final goal is the enable the Samba replacement for the SMBv2 protocol.
From the Entware-ng repository install log, I was able to figure out that wget fails to establish an https connection. I edited the Entware-ng script in /usr/local/zy-pkgs/etc/init.d/ and replaced wget with curl -k -L, but now I get the following errors:
[09:47:27] Info: Basic packages installation...
[09:47:28] Collected errors:
[09:47:28] * opkg_download: Failed to download https://zyxel.ddnss.eu/Users/Mijzelf/Entware-ng/binaries/armv5/Packages.gz, wget returned 1.
[09:47:28] Downloading http://pkg.entware.net/binaries/armv5/Packages.gz.
[09:47:28] Updated list of available packages in /opt/var/opkg-lists/packages.
[09:47:28] Downloading https://zyxel.ddnss.eu/Users/Mijzelf/Entware-ng/binaries/armv5/Packages.gz.
[09:47:28] * opkg_install_cmd: Cannot install package kernel-2.6.24-support.
[09:47:28] Unknown package 'kernel-2.6.24-support'.
Please can anyone help me solve this?
Thank you in advance
I think the server has been reconfigured. This redirect has not always been there, else MetaRepository couldn't have worked.
I'll try to contact the maintainer.
Maybe you'd better change https to http. The installer uses firmware curl/wget, and I can imagine it can't handle the encryption used.
Hi Mijzelf,
thank you for your reply. The reason why I tried to use "https" instead of "http" is that if I specify "http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/" and "http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/" in the MetaRepository configuration page, the packages list stays empty (of course I clicked the "Retrieve packages list" button again). Here is the log from /admin/zy-pkgs/MetaRepository:
HandleZYPKG_INFO /NSA325-v2/4.80/zypkg
FindApp md5sum found /sbin/md5sum
ReadConfig Repositories
Start of block
http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/ ZyXEL
http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ Mijzelf
/i-data/md0/admin/MyRepo/ Local
End of block
9 start: 09:20:27
7 start: 09:20:27
8 start: 09:20:27
7: FetchZYPKG_INFO /i-data/md0/admin/MyRepo/ 7 Local
9: FetchZYPKG_INFO http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/ 9 ZyXEL
7: FindApp curl found /usr/bin/curl
8: FetchZYPKG_INFO http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ 8 Mijzelf
7: Fetch /i-data/md0/admin/MyRepo/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/i-data_md0_admin_MyRepo.tmp failed
7: Fetch /i-data/md0/admin/MyRepo/ZYPKGS /i-data/md0/admin/zy-pkgs/MetaRepository/i-data_md0_admin_MyRepo.tmp failed
8: FindApp curl found /usr/bin/curl
7: Failed
7 stop: 09:20:27
9: FindApp curl found /usr/bin/curl
9: Fetch http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4_stock_packages/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw4_stock_packages_.tmp succeeded
8: Fetch http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw4_.tmp succeeded
9: tar: invalid tar magic
8: tar: invalid tar magic
9: rm: can't remove '/i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw4_stock_packages_.400.md5': No such file or directory
8: rm: can't remove '/i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw4_.400.md5': No such file or directory
9 stop: 09:20:27
8 stop: 09:20:27
Pushlist...
ReadConfig Pushlist
Start of block
End of block
Blacklist...
ReadConfig Blacklist
Start of block
YouNameIt
End of block
/bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/List.19030
Sort...
Choose packages...
Choose DEPS...
Create ZYPKG_INFO.tgz
TarHeader
Fetch /i-data/md0/admin/zy-pkgs/MetaRepository/NSA325-v2/4.80/zypkg/ZYPKG_INFO.tgz - succeeded0 -
This is weird.
8: Fetch http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz /i-data/md0/admin/zy-pkgs/MetaRepository/http___zyxel.ddnss.eu_Users_Mijzelf_zypkg-repo_fw4_.tmp succeeded 8: tar: invalid tar magic
MetaRepository first tries to download ZYPKG_INFO.tgz, and if that fails, it tries ZYPKGS. On zyxel.ddnss.eu there is no ZYPKG_INFO.tgz, so that yields a 404. But in your case it doesn't. According to curl the download succeeded, so MetaRepository continues to unpack it, but the downloaded file isn't a tar archive.
Why doesn't you box get a 404? Is it behind some transparent proxy or fancy firewall? What happens if you in the same network try to download http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz in a browser?
Thank you again. I have no firewall here. If I try to download http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz in a browser I get a 404 Not Found but before it is redirected to the https version of the same url.
If I connect to my NAS via telnet, this is the curl verbose output:
~ # curl -v http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz >/dev/nullAbout to connect() to zyxel.ddnss.eu port 80 (#0)Trying 158.101.164.98... connectedConnected to zyxel.ddnss.eu (158.101.164.98) port 80 (#0)
GET /Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz HTTP/1.1
User-Agent: curl/7.18.2 (arm-unknown-none) libcurl/7.18.2 OpenSSL/1.0.1j zlib/1.2.5
Host: zyxel.ddnss.eu
Accept:/< HTTP/1.1301 Moved Permanently
< Date: Sat, 21 Mar 2026 20:20:55 GMT< Server: Apache/2.4.58 (Ubuntu)< Location:https://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz< Content-Length: 354< Content-Type:text/html; charset=iso-8859-1<
{ [data not shown]
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 354 100 354 0 0 5222 0 --:--:-- --:--:-- --:--:-- 0* Connection #0 to host zyxel.ddnss.eu left intactClosing connection #0
As you can see, it seems not to follow the redirect. As a matter of fact this is the html page it gets:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head>
<title>301 Moved Permanently</title>
</head><body><h1>Moved Permanently</h1>
<p>The document has moved <a href="https://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz">here</a>.</p>
<hr>
<address>Apache/2.4.58 (Ubuntu) Server at zyxel.ddnss.eu Port 80</address></body></html>This is the reason why it does not get a 404 Not Found.
If I try adding the -Lk parameters to the curl command:
curl -v -Lk http://zyxel.ddnss.eu/Users/Mijzelf/zypkg-repo/fw4/ZYPKG_INFO.tgz >/dev/null
then it follows the redirect, it ignores the https certificate so that finally it gets the 404 Not Found response:
< HTTP/1.1 404 Not Found
< Date: Sat, 21 Mar 2026 20:34:02 GMT
< Content-Length: 277
< Content-Type: text/html; charset=iso-8859-1NSA325v2 is not able to deal with https certificates: a plain curl (without -Lk options) is not enough to make it fulfill a download request successfully.
This behaviour explains why when the
http://zyxel.ddnss.euused to deliver its content over http ONLY (not https), NSA325v2 had no issues going through the whole process of installing the Entware-ng repository.0 -
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
