unable di disable MPro Mesh
asalmaso
in Home Router
I can't disable MPro Mesh from our DX 3301-to.
The switch is off, but when I try to disable 5GHz Wi-Fi, I get the following message:
"5GHz cannot be disabled when MPro Mesh is enabled."
what i need to do?
I think your device has MESH enabled, so you may need to log in to your device and then disable MESH. Login information should be on the back label.
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
