Request for Firmware Download – VMG3625-T50B
ahmedzakaria
ahmedzakaria Posts: 2 image  Freshman Member
Dear Zyxel Support Team,
I hope you are doing well.
I have a Zyxel VMG3625-T50B router (model: EG01V1F), and I am currently trying to find the latest firmware for this device. Unfortunately, I could not find the firmware file available for download on the official website.
Could you please provide me with the latest firmware version or a direct download link for this model?
Thank you in advance for your support.
Best regards,
Ahmed Zakaria
  • vynsans
    vynsans Posts: 2 image  Freshman Member
    Same here. All firmware has completely disappeared from the download section. Are updates no longer being provided?
    After looking into it, it seems this model may now be restricted to ISP distribution, wich could explain why public firmware is no longer available. I'm not entirely certain, tough, and would appreciate any clarification on what's going on.
  • Liba
    Liba Posts: 218 image  Master Member
    First Comment First Answer Third Anniversary
    You can find it here.
    https://www.zyxel.com/service-provider/emea/en/products/dsl-cpe/vdsl/vmg8623vmg3625emg5523emg3525-t50b-series
  • vynsans
    Thanks for sharing the link. That's exactly what we were looking for.
    It does seem like Zyxel has moved these firmware files under their service provider section, wich supports the idea that this model is now primarily distributed and maintained through ISPs rather than as a fully retail-supported device. That would explain why the firmware disappeared from the standard download pages.
    Given that, it's also likely that we won't be receiving regular public firmware updates anymore, and any future updates (if they happen at all) will probably be pushed only through ISPs.
    Appreciate you pointing this out.
