FWA505 rejects Mozillion 5G SIM
Crofty
I have a FWA505 router , works fine with EE SIM, trying to use Mozillion SIM and the SIM LED flashes blue and the is not lit and the Internet LED is RED.
The Mozillion sim works fine in a Samsung Phone and has no PIN.
I have reset the FWA505 and its on the latest firmware.
Mozillion is a VISP and uses EE.
Any advice how to fix it ??
Hi @Crofty,
Welcome to the Zyxel Community!
To help us diagnose the issue accurately, please check the following to rule out common causes:
- Verify the SIM Card
The flashing blue SIM LED on the FWA505 indicates the SIM card isn't being correctly recognized or authenticated. Please ensure it's properly inserted and check its status in the local GUI (detailed Cellular info page). - Check 5G & APN Settings
In the local GUI, go to: Network Setting > Broadband > Cellular Band- Set Preferred Access Technology to include 5G or select NR5G-NSA/4G (Auto Switch).
- Enable Band Auto Selection.
- If needed, manually configure APN under: Network Setting > Broadband > Cellular APN
Please let us know if the issue persists after the above checks, and we will proceed with further investigation at that time.
Zyxel Tina
0 - Verify the SIM Card
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
