FWA70 disconnect provider+ scheduled reboot
JBL
JBL Posts: 3 image  Freshman Member
I have 2 problems with this router. Our provider Odido disconnects the 4g/5g connection exactly after 24 hours. The connection is back after a few minutes but the clients cannot connect to the internet anymore from the LAN. After a reboot everything is working fine. I scheduled a reboot in Nebula at 01:00 am but the router does not reboot. Automatic firmware update is disabled. On other locations i use the FWA710, i have no problem, that router is working fine.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,594 image  Zyxel Employee
    Hi @JBL ,
    Regarding the scheduled reboot not working as expected, this will be fixed in the next official firmware release.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @JBL ,
    To better assist you, could you let us know whether the FWA70 itself has internet access after reconnecting? You can check this by going to Maintenance > Diagnostics > Ping and pinging 8.8.8.8.
    Also, do you know what time the provider Odido disconnects the 4G/5G connection each day?
    Lastly, could you export the log after Odido disconnects the 4G/5G connection, the connection back however there is no Internet connection with LAN devices and then share it with us? You can find this under System > Monitor.
    Zyxel_Judy
  • Zyxel_Judy
    edited June 23
    Regarding the scheduled reboot you configured in Nebula at 1:00 AM, however it appears the router did not reboot as expected, could you please provide the Nebula Organization & Site name and enable Zyxel Support access so we can look into this on our end.
    Zyxel_Judy
  • JBL
    Odido disconnects the connection after 24 hours connection time, so these are not fixed times of day.
    I will be on-site next week, so I will be able to perform the test and send you the logs.
    Thank you.
  • Zyxel_Judy
    Hi @JBL ,
    Zyxel_Judy
Nebula Tips & Tricks
