Rooting of USG60W
G_L
G_L Posts: 3 image  Freshman Member
edited April 2021 in Security
Guys trying to paste a rooting I had in one of my CISCO routers and i find it EXTREMELEY difficult to do this in Zyxel. I am not at all expert so your step-by-step help will greatly appreciated.
Please also note that the CISCO router was the router to the outside world(intenet -e.g external IP 164.212.25.225) and my internal network. Now I have put between CISCO (192.168.2.1) and my internal network the ZYXEL USG60W (192.168.1.1).
I have on purpose provided 3 IPS (public ip, router Ip and Zyxel ip) to be inlcluded in your step by step answer.
Appreciated very much
    PeterUK Posts: 4,179 image  Guru Member
    Put the USG60W in expert mode
    Network > NAT
    add
    classification = virtual server
    Incoming interface = wan1
    Original IP = wan1
    (create new object > address
    Name =wan1
    address type = INTERFACE IP
    interface = wan1)
    mapped IP = User Defined
    User-Defined mapped IP = 192.168.2.200
    port mapping type = ports
    original start port =5390
    original end port =5399
    mapped start port =5390
    mapped end port = 5399
    do the same to the rest in your list
  • GLou
    GLou Posts: 10 image  Freshman Member
    Thanks.
    You havent define port type, tcp/udp most propably will be any but i am confused with port numbers.
    I need to use the 50000 -50011 as these come from my Divar and also use the 443 porr external whichb is secure.
    Why do you also use a range i.e 5390-5399
    Do I also need to go to ,security, to setup something?
    I'm not sure I get what you want? You want the setup on Cisco to be on USG60W from your screenshot?
  • CHS
    CHS Posts: 181 image  Master Member
    Hi @G_L
    I guess you are looking for setup port forwarding configuration on USG.
    You can reference to FAQ first.
    And of course policy control rule is required.
  • GLou
    Have tried and is a bit not that straight fwd to me as was the CISCO setup
