Rooting of USG60W
Guys trying to paste a rooting I had in one of my CISCO routers and i find it EXTREMELEY difficult to do this in Zyxel. I am not at all expert so your step-by-step help will greatly appreciated.
Please also note that the CISCO router was the router to the outside world(intenet -e.g external IP 164.212.25.225) and my internal network. Now I have put between CISCO (192.168.2.1) and my internal network the ZYXEL USG60W (192.168.1.1).
I have on purpose provided 3 IPS (public ip, router Ip and Zyxel ip) to be inlcluded in your step by step answer.
Appreciated very much
Put the USG60W in expert mode
Network > NAT
add
classification = virtual server
Incoming interface = wan1
Original IP = wan1
(create new object > address
Name =wan1
address type = INTERFACE IP
interface = wan1)
mapped IP = User Defined
User-Defined mapped IP = 192.168.2.200
port mapping type = ports
original start port =5390
original end port =5399
mapped start port =5390
mapped end port = 5399
do the same to the rest in your list
Thanks.
You havent define port type, tcp/udp most propably will be any but i am confused with port numbers.
I need to use the 50000 -50011 as these come from my Divar and also use the 443 porr external whichb is secure.
Why do you also use a range i.e 5390-5399
Do I also need to go to ,security, to setup something?
I'm not sure I get what you want? You want the setup on Cisco to be on USG60W from your screenshot?
Have tried and is a bit not that straight fwd to me as was the CISCO setup
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
