Updating XS1930-12HP to
Hi @AlexDayne
Some forum users have upgrade to the latest firmware version.
What method did you do when upgrade your switch? Access to the switch by direct connecting PC? Or upgrade via VPN?
Zyxel Melen1 -
I'm accessing the XS1930-12HP locally, not through a VPN or reverse proxy. My PC and the switch are on the same subnet. Ports are reachable, and the login page returns HTTP 200 OK.
During the firmware upload, ping remains continuously available with no packet loss and the switch does not appear to reboot. Firefox returns either 502 Bad Gateway or NS_ERROR_NET_EMPTY_RESPONSE after a few seconds. Tested with Edge and Chrome as well. I'm uploading the extracted V4.80(ABQF.5)C0 firmware file.
where
To upgrade the switch firmware, browse the location of the binary (.BIN) file and click Upgrade button.
there is a Firmware slot before you upload change this to the the other number listed Current Boot Image slot shown above
Hi @AlexDayne
Please help to record a video by Jam.dev plugin which will record the browser network for us to check this issue. And please also collect the switch tech support file to us.
[Switch] How to collect the Tech-support Info on V4.80 firmware version and newer? — Zyxel Community
I will send you a message and you may provide the information there.
Zyxel Melen0 -
Hi @AlexDayne
Additionally, you may also try other methods to upgrade your XS1930-12HP.
- Upgrade by using ZON utility.
- Upgrade by using FTP.
Hope this helps.
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
