How to update USG FLEX 200H from V1.10(ABWV.1) to newest firmware?
baba
baba Posts: 293
image  Master Member
Hi all,
how to update USG FLEX 200H from V1.10(ABWV.1) to newest firmware safely? It's a very first beta version, no standby image is shown in the UI.
Thank you!
    PeterUK Posts: 4,835
    image  Guru Member
    edited August 11
    It is new out the box? Normally first power up it will well must download the update.
    If it old and never been kept update date then you can download the new firmware from
    https://portal.myzyxel.com/my/firmwares
    if you select your Model you can down 1.38(ABWV.0) and 1.39(ABWV.0) if you want the last
    to show standby image do the following
    to save
    copy running startup
    It would then be recommended to reset to default after update
  • baba
    baba Posts: 293
    image  Master Member
    edited August 11
    Thanks @PeterUK ! No it isn't new, so I will download 1.39(ABWV.0).
    Is there any special upgrade path from  V1.10(ABWV.1) to 1.39(ABWV.0) needed? I want to keep the config.
    Thank you!
    image  Guru Member
    Well there's no way to download older firmware to do a step by step upgrade I'm not sure how compatible your config will keep, it may update fail go back to the old firmware slot with the new firmware in standby.
  • baba
    baba Posts: 293
    image  Master Member
    Thanks @PeterUK . So if config could not be loaded with newest firmware. USG switches back to old firmware with old config automatically?
    image  Guru Member
    yes you can backup your config too before you upgrade
  • Zyxel_Luna
    Zyxel_Luna Posts: 122
    25 Answers First Comment Friend Collector
    image  Zyxel Employee
    edited September 3 Answer ✓
    Hi @baba ,
    You can directly upgrade the USG FLEX 200H from V1.10(ABWV.1) to the latest version V1.39(ABWV.0).
    Below is the firmware update guide for the USG FLEX H series for your reference:
    [USG FLEX H]How to update firmware on the USG FLEX H series — Zyxel Community
    Please rest assured that Partition Boot Selection is supported starting from V1.10.
    Your original settings will be preserved after the upgrade. However, we still highly recommend backing up your configuration file before proceeding.
    Below are the steps to back up the USG FLEX H configuration file for your reference:
    [USG FLEX H] How to download configuration file via Local WEB GUI? — Zyxel Community
    Pre-Upgrade Precautions
    • Backup Configuration: Always save and back up your current configuration file to your local computer before starting any upgrade process.
    • Do Not Power Off: Once the firmware transfer begins, do not turn off or interrupt power to the device. The process can take between 5 to 15 minutes.
    Please let us know how it goes. Have a wonderful day!
    Please refer to the following FAQs:
    [USG FLEX H] Can the device be upgraded directly from V1.10 to the latest V1.39?
