How to migrate from USG 50 to USG 100?
Hi @follet,
It could be blocked because of mismatch physical interface. If so, i would suggest set up manually from beginning.5
Hi @follet
Because it will check the model name of configuration file header when you apply configuration file to USG-100. It only accept the same model.
You can remove the first three line of the configuration file header to bypass checking and try it again.
(Please note that make sure the firmware version is same before your perform this operation.)
I see on my ZyXEL USG-100 firmware version is too old. I tried to update it, but it finished with error (see below)
File path depends on OS, I use Ubuntu. As for main topic, I can't restore USG 50 conf file even without 3 first rows...
Hi @follet ,
Updated wrong firmware, the firmware name should be “330AQQ7C0.bin”.
You can get correct firmware from link below.
Firmware link:
ftp://ftp2.zyxel.com/ZYWALL_USG_100/firmware/ZYWALL%20USG%20100_3.30%28AQQ.7%29C0.zip
Unfortunately, After deleting first 3 lines from conf files, The Upload button is deactivated and grey...Zyxel_Cooldia said:You can remove the first three line of the configuration file header to bypass checking and try it again.
Hi @follet,
It could be blocked because of mismatch physical interface. If so, i would suggest set up manually from beginning.5 -
Yes, I done it manually.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
