[NEBULA] AP not getting recognized
I have the NWA1123-ACv2 Access Point. When I plug it into a POE switch at work it correctly connects to the network and works like an AP. When I take it home and plug it into a non-POE switch with the power supply attached to it, it does not work.
Thoughts
Thank you
Kevin
Hi @kevin1000
What does "It does not work" mean?
Does the device boot with the power supply? Or does not it boot?
I think if you you provide more information we will be able to help you.
Regards
the lights stay blinking green and orange and never go solid green. I can connect to it but get no traffic
Kevin
Hello @kevin1000 ,
Based on the description, if the NWA1123-ACv2 LED is blinking green & orange, it means that the AP cannot boot up properly you shouldn't be able to connect to the AP.
I would like to clarify the following:
1. May I know the specific LED light?
2. The power supply that you are using is the adapter provided by Zyxel, right? If no, please help to provide a photo of the input/output power information.
3. When you are at the work place, you could see that the NWA1123-ACv2 is online on Nebula Cloud?
Thanks.
JonasJonas,0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
