[NEBULA] Cloud authentication
laninformatica
laninformatica Posts: 2
image  Freshman Member
edited April 2021 in Nebula
I add a new user account for authenticaition but not work.
  • laninformatica
    Sorry, but I need to create a new account administrator
  • Zyxel_Freda
    Zyxel_Freda Posts: 397
    25 Answers First Comment Friend Collector Third Anniversary
    image  Zyxel Employee
    Hi @laninformatica,
    May I know what's the authentication you want to use?
    There are four types of the cloud authentication account, and user account type is used to do 802.1x authentication.
    If you have set the SSID with WLAN security "WPA2-Enterprise with Nebula cloud authentication" but can't connect to the SSID, please share more information for us about the issue symptom.
    Thanks.
  • laninformatica
  • Zyxel_Freda
    Hi @laninformatica,
    If you want to create an administrator, please go to Organization > Administrator to add a new account and activate the account.
    After add the administrator, please note that if the email account was never registered in Nebula, please sign it up first and activate the account by the link in the email.
    When the account was activated and able to login to Nebula, you can access the organization.
    Thanks.
Nebula Tips & Tricks
