The NWA130BE does not work with another network.
Hey,
I have a problem with my access point. It works perfectly in one network where it's connected to a switch. Now, I wanted to use it for another network via a POE adapter and connect it directly to my FRITZ!Box, but it's not working that way. The POE adapter has a power output of 40W. It seems to be online in the Nebula app, but the network is not showing up, and the light keeps blinking green. Does anyone have an idea what I can do? I have already removed it from the Nebula app and also reset it to factory settings.
Best regards,Roman
Hi @Roman1408 ,
Could you provide more details on the issue when the NWA130BE is connected to the PoE adapter and directly to the FRITZ!Box? Does it mean there is no SSID broadcast from the NWA130BE, or is there another issue?
If the NWA130BE’s LED keeps blinking green, you can check the possible reasons in this article.
After checking the reason, however, you still need more support from us, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 798 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
