Synchronization Issues with Nebula USG FLEX 500H HA on-premises.
Pedroj
Pedroj Posts: 68 image  Ally Member
First Comment Seventh Anniversary
Hello, I'm having synchronization problems with a Nebula installation of two USG FLEX 500H units in HA. The installation is on-premises, but I don't see the updated configuration in some settings in Nebula.
For example, in Interface everything is set to default, but this is not the case in the local configuration.
In configure---Firewall everything is set to default.
The device status appears to be fine with updated data.
Connectivity with Nebula is working correctly.
What could be the problem?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,992 image  Zyxel Employee
    Update:
    This issue is due to the device startup configuration have one command with empty characters which cause sync failed. Removing this command solves this issue.
    Zyxel Melen
Nebula Tips & Tricks
