Slow copy speed PC to NAS
2»
  • Perihelion
    Perihelion Posts: 3 image  Freshman Member
    I have the same problem. But what do you mean by chaning sync to async? How do I do that? Noob question, sorry.
  • Mijzelf
    Mijzelf Posts: 3,078
    image  Guru Member
    You'll have to edit the /etc/exports file (man exports) which defines the NFS shares on the NAS, and change 'sync' to 'async'.
  • Perihelion
    *cough* I dont think I'm on the same level as you there. How do I edit or find that file. I'm on Windows.
  • Mijzelf
    image  Guru Member
    Enable the ssh server, and use WinSCP.
  • Gahua
    Gahua Posts: 1 image  Freshman Member
    edited November 2019
    I have the same issue, and I'm getting disappointed with that NAS drive from Zyxel. It seam the software support is very poor.
    I'm not a powerful user, and I could't do anything with WinSCP, even I could't login into drive. "Mijzelf" could you give more detail explanation how to fix the problem?
    Other problem that I have is CPU use of 100%.
