NSA310 network problem
Gabor
Gabor Posts: 2 image  Freshman Member
I have a NSA310 and a strange problem. It is not visible on the network, I have configured a static IP for that, it is not visible in the router also. But sometimes I can browse it from my smartTV and answers on ping command. Sys led is blinking green, only the yellow LED is blinking on the Ethernet port.
I have also tried with NAS Seeker Utility, nothing.
Can you help me?
Thank you.
  • Sakura_T
    Sakura_T Posts: 101 image  Ally Member
    edited April 2020
    Check network settings, make sure you configure the correct IP address for the gateway and DNS in your network.
  • Gabor
    Oh, it seems a HDD issue. After removing the HDD it is working fine.
