ZyWALL 310 unexpected reboot
I have the same issue with two Zywall 310 firmware 4.35 (AAAB.2)C0
some resolution?
Regards
Yes, the new firmware was solved the problem.
(we've gotten a temporary fw too.: V4.31(AAAB.1)ITS-WK45-r86201)
Currently we're using this version: V4.35(AAAB.0)
Thank you very much for the reply.
I see that our firmware is later than yours ...
I don't know if I should pull back with the firmware
Hi @SergionCTRL
We have improved some of system stability issue. I will send download link by private message.
I have a USG1900 that reboots randomly. On the console:
*** NMI Watchdog interrupt on Core 0x00 ***
$0 0x0000000000000000
0x0000000000000000 v0 0 xffffffff80a40000 v1 0x0000000000000000 a0 0xffffffffc07d12 08 a1 0x0000000000000003 a2 0x80000000b184a408 a3 0 x80000000b184a420
*** NMI Watchdog interrupt on Core 0x01 ***
and so on for each core. Can somebody analize that stuff ? I can send the file containing the console messages
many thanks
Paolo
@noc_aba
Sorry for causing your inconvenience and bad user experience.
Can you share the complete console dump information (during issue occur), and diagnostic information(after issue happen) for our checking further?
hi, yesterday we changed our zywall 310 for the new atp800 and we have the problem of unexpected reboots again, specifically today at 10am it has restarted itself, do you have any firmware that will fix it? V4.55 (ABIQ.0) is currently installed0
Hi @SergionCTRL,Can you send me your configuration and diag-info in a PM for further analyzing.0
Hi, we also have a Zywall 310 with sudden reboots and it looks like it is once every month! There is no scheduled restart configured or an auto update with restart. The logs are overwritten everytime (mostly because of the [SSI] Create the default trusted certificate's symbolic link logs, is there a way to disable these logs?) so I can not see what happend. The firmware running is V4.38(AAAB.0).
There is a Hotel running after the Zywall so I am not very happy with this happening.0 -
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
