[NEBULA] Is it possible to create Virtual WAN port
LarrY_FIN
LarrY_FIN Posts: 6 image  Freshman Member
First Comment Eighth Anniversary Nebula Gratitude
edited April 2021 in Nebula
Hi!
Our customer has multiple public IP-addresses, is it somehow possible to create virtual wan port for those, same like as USG series? If not, is the feature coming in near future?
  • FrankIversen
    FrankIversen Posts: 92 image  Ally Member
    Ideas master First Comment Friend Collector Third Anniversary
    Does this mean we can't create a virtual lan adapter as a gateway for dmz?
  • Zyxel_CSO
    Zyxel_CSO Posts: 489 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    edited June 2017
    @FrankIversen
    NSG does not support the establishment of virtual lan adapter for dmz at present. We are still under evaluation of the virtual interface and will get back to you as long as the feature is confirmed in our future roadmap.
    Zyxel Nebula Support
  • FrankIversen
    we have 2 public wan ips. we want the it-department to run internally on LAN2 and use 1 specific wan ip for outbound traffic (due to some dashboards around which only accepts communication from our public ip).
    the other
  • Zyxel_Barney
    Zyxel_Barney Posts: 85 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    edited March 2018
    @FrankIversen
    This application requires Nebula CC to support both Virtual interfaces and Policy Routing.
    Policy Routes will be introduced to Nebula on Phase 4, scheduled to release on the 2nd half of 2018.
    Unfortunately, there has been no plans yet to support virtual interfaces on the NSG. I will create this request under our Ideas section. With enough likes, perhaps we can add this in to our road map faster!
    Regards,
    Barney
  • CommsCo
    CommsCo Posts: 22 image  Freshman Member
    Has this now been implemented?
    If so, any help documents for it?
    Many thanks
    Richard
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Guru Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    edited January 2019
    Hello @CommsCo
    About policy route, yes it has been implemented on September :), for the WAN virtual interface it's in our roadmap already but we're still working on this I can't give you a precise schedule in this moment, please stay tuned.
    /Chris
  • Azzie
    Azzie Posts: 2 image  Freshman Member
    edited April 2020
    Hello @Nebula_Chris
    has the Virtual IP been implemented? I am facing the same situation as Larry_FIN. I need to use multiple public IPs on a single WAN port of a NSG200
    Many thanks
  • Zyxel_Chris
    Hi @Azzie
    Welcome to the Nebula community!!☺️
    May I know if you're planing to use it on virtual server? If it is the case then please refer to the below screenshot, you can still put IP in Public IP column, which can get same result as virtual interface.
  • Azzie
    Hello @Nebula_Chris ,
    I've tested it and it seems to work, many thanks for the info!
Nebula Tips & Tricks
