VPN100: Repetitively error: myZyXEL.com Certificate download has failed
[Deleted User]
Hi, I get repetitively this error in the log file (once a day): myZyXEL.com Certificate download has failed.
Device is a VPN100 with FW 4.35(ABFV.3).
Any ideas? Regards, Dany
Hi @Dany,
The error comes from "Certificate Update" in Configuration > Security Service > SSL Inspection > Certificate Update.
We have fixed the issue on the update server.
Try to click "Update Now" and SSL certificate is able to be downloaded successfully.
5
Hi @Dany,
5 -
Hi @Zyxel_Emily
Thank You for Your help. Solution has worked. After one "manual Update Now", the "Auto Update" was successful.
I have a USG Flex 700 running firmware version 5.31(ABWD0) which is having the same continuous error "2022-09-26 14:45:03 error myZyXEL.com Certificate download has failed.).
I have tried unsuccessfully to perform the update manually, but it continues to fail that way as well. "SSL Certificate download has failed. (failed) at Mon Sep 26 15:18:05 2022"
How can I correct this issue?
Jay0 -
jayd691,
I saw you create another one Flex 700 - Certificate download has failed
I will reply to the one you create, thank you.0
- 588 USG FLEX H Series
- 476 News and Release
