NAS540 Having trouble to set up iphone zcloud app
kafandiyev
recently purchased nas 540 but I never could reach it through zCloud app.
I used Zyxel drive which technically works but extremely slow. But I could never make zCloud app to find and connect to my Nas540.
On the Find a NAS screen on the app my NAS appears with ip 192.168.1.150 Whenever I press on it it says device not found.
I skip to manually adding the device I enter my hostname with and without http:// or https:// before it and enter username and password but it can't connect.
I'm totally lost and I don't know how to do advance settings on my router or computer or NAS540..
Would appreciate any help
#NAS_September
@kafandiyev,
What's your mobile operating system?
You can first check if browser of phone can access your NAS540.
You can make with DDNS free service, and a host name like (noip.me), but you have to open ports on your router. I use a solution like that without problem for external access. Other solution I use, is access with private VPN !0
Are you unable to connect to the NAS in your local network as well (using local IP)? Or is it only externally?
I'm having similar issues. I registered an address with zyxelcloud, and I can ping that address from an external computer so that seems to be working. I have enabled uPNP on my router and also gone through the uPNP settings in the NAS. When I try to connect through zcloud on my android phone though, it says failed to connect to NAS, check NAS IP, DYNDNS or http.... Also I can use the twonky player on my phone when on my local network, should it also work over WAN?
@Kaneda
Do you add the port number while you type the FQDN in the zcloud APP?
I guess your problem would simular as below link as fotget to add port nubmer:
https://homeforum.zyxel.com/discussion/449/nas-326-failed-https#latest
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
