NSA325-v2 How ti access over internet
Perkeo
I ha e ben usino my NAS NSA325-v2 Maine Yasmine storage device ti share files overdose local network. I do not know to access it when I am away from home. Please help!
#NAS_October
#NAS_October
Hi @Perkeo
NSA325 v2 supports MyZyXELcloud, you can install it thgough the package list.
Then you can visit mycloud portal and register an user account, and through portal, you can have a DDNS domain for your NSA325 v2 and map your device with the DDNS, UPnP.
Threfore, after all finish, then you can access your NSA325 via the DDNS through internet.
PS. The router should support UPnP and NSA should behind the router directly.
You can refer the help page to finish the process: https://mycloud.zyxel.com/help.
Thanks.0 -
hope it helps ...
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=014720&lang=EN
But I used ZyXEL Drive app, not zCloud.
Thank you so much for the information. The step by step instructions are really easy to follow. I had done parts of the process but I was missing a lot. Now I am able to access my NAS remotely. Thank you so much for sharing, I really appreciate your help.2
When following the steps to add NAS325 v.2 it gives me an error that it has already been added. But not in my account but in someone else's. Is there an option or way to remove it from the other account
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
