About the Multy X network capabilities (DNS, LAN, IP Reservation, Port Forwarding etc)
Baldrick
My setup is a VM cable connection and I want to replace the provided router completely, putting it into modem mode.
Does the Multy X support any of the following:-
- Changing the DHCP scope, already have a wired network with a few devices on static IP; can I change the DHCP scope to my range so I don't have to re-address?
- Likewise can it handle DHCP reservations for some devices?
- Can I change the DNS from the ISP provided servers?
- Does it support port forwarding? Also is there a "DMZ mode" or similar, where all inbound traffic is forwarded to a certain device?
- Finally as each Multi X device has LAN ports can I use the remote unit as a LAN extender? (Getting rid of Powerline adaptors which "sort of" work...)
To my knowledge, Multy X does not yet support 1, 3, 4 that you mentioned.I recommend Zyxel Armor Z2 (AC2600). I have this one, it works pretty well and it supports all feature that you mentioned.For your reference: http://www.zyxel.com/products_services/armor_z2.shtml?t=p#productDetailTab50
@BaldrickArmor Z2 is AC2600 MU-MIMO Wireless router,it has good coverage than other router,I also think you can consider this model.
https://www.amazon.co.uk/MU-MIMO-Wireless-StreamBoost-Beamforming-Antennas/dp/B01GHAWAFY/ref=sr_1_1?ie=UTF8&qid=1508901113&sr=8-1&keywords=NBG68170
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
