NAS 326 TRANSFER ERROR VIA FTP: TOO MANY OPEN FILES
JUKE
Hello. When I try to upload a lot of files via FTP (Filezilla client) the NAS works pretty good until it transfer about 1300-1500 files/folders and then I get an error that stop the connection to the server saying "too many open files". Total size I need to transfer is 360GB. I have tried a lot of Firewall, Router and Filezilla configuration, a different FTP client, both windows 7 and 10 but I cannot get rid of this. It happen both via Ethernet as via Wifi.
LOG:
What to do? :-/
#NAS_November
LOG:
Starting upload of E:\98-OLD foto Samsung\Whatsapp pics\IMG-20151114-WA0008.jpg
Status: Retrieving directory listing of "/admin/Whatsapp pics"...
Status: Starting upload of E:\98-OLD foto Samsung\Whatsapp pics\IMG-20151114-WA0007.jpg
Command: PASV
Response: 227 Entering Passive Mode (192,168,0,4,38,12)
Command: STOR IMG-20151114-WA0007.jpg
Response: 421 The connection couldn't be accepted: Too many open files
Error: File transfer failed
Status: Starting upload of E:\98-OLD foto Samsung\Whatsapp pics\IMG-20151114-WA0009.jpg
Command: PASV
Response: 227 Entering Passive Mode (192,168,0,4,255,237)
Command: MLSD
Response: 150 Accepted data connection
Response: 226-Sorry, we were unable to read [.]
Response: 226-Options: -a -l
Response: 226 0 matches total
Command: PASV
Response: 227 Entering Passive Mode (192,168,0,4,210,70)
Command: STOR IMG-20151114-WA0008.jpg
Status: Starting upload of E:\98-OLD foto Samsung\Whatsapp pics\IMG-20151115-WA0007.jpeg
Command: PASV
Response: 227 Entering Passive Mode (192,168,0,4,176,85)
Command: STOR IMG-20151114-WA0009.jpg
Command: PASV
Response: 227 Entering Passive Mode (192,168,0,4,168,70)
Command: STOR IMG-20151115-WA0007.jpeg
What to do? :-/
#NAS_November
Try maximum the connection limit in NAS326 ftp setting.
Then use filezilla and set the limit number of simultaneous connections of transfer setting as 1 and try it again.
I have just tried but it didn't help :-/0
in that picture you cannot see it because I have deleted the history but this fail happens after it has transferred about 1000 files successfully0
Perhaps you router think it's an attack because too many attempt/connect and block momentally the connection ?!0
How to know that? :-)0
and what to do as test?0
I run the test to transfer photos around 13,000, but doesn't meet the problem.
If you would like to know the problem is related to router, then you can use static IP address on your PC and NAS326 and directly connect both by cable and run FTP.
If no problem, then you can confirm the problem might caused by router.1 -
Hello and thanks for your advice. I am going to try tomorrow and I will post how it goes :-) Have a nice day!0
Feedback us after you testing the tips from Mihawk.
(Question : Are you in IPV4 or IPV6 on local network ? If IPV6, turn to IPV4 est test again)1
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 469 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
