Plex.TV for NAS326??
tomrc
Posts: 13 Freshman Member
Someone know if there is any plan to implemented plex.tv on NAS326.
or someone know any way to install plex.tv easy
#NAS_October
#NAS_October
Best Answers
Hi @tomrc,
You have possibility to install it with the 3rd party repo from Mijzelf.
You can find more info here : http://zyxel.nas-central.org/wiki/3rd_party_zypkgs
After you install repo, you can install package plex.
Best Regards0 -
Thanks, work fine. Regards0
Hi @tomrc,
Best Regards0 -
can you help me with a tutorial with print screens ? or video ? i don`t now even where to start i read everything but i fail install the repo with zy-pkgs0
Dayday:
First question you able to go the admin\zy-pkgs?
if you response is yes
For me the key was rename from MetaRepository_20160513_arm_013.pkg to this "MetaRepository.zpkg" then
webinterface execute 'Retreive list from Internet' or "Update list from Internet"
Let me know were you feel that you are lost.
Regards
P.D: I try several time with the full name and sometimes w
im trying to figure out how to add plex to my nas326 please help.0
Go to
http://zyxel.nas-central.org/wiki/3rd_party_zypkgsHow to install
Download MetaRepository_20160513_arm_013.pkg , rename to "MetaRepository.zpkg" , and put the text file in \\<NAS>\admin\zy-pkgs\. Then in the package menu press on the 'Retreive List From Internet' button. (On firmware 5.20+ this is the 'Cycle icon' in 'App Center->Browse->All Apps'). Only the MetaRepository package should show up. Install it, and re-request the list. You should see the (MetaRepository). If you still see only MetaRepository, disable it, enable it again, and retry.
After the install metarepository, click on them, install plex
For anyone coming to this thread who has a NAS326 note that the admin folder mentioned is NOT off root of the volume e.g. /admin/ but is located under /i-data/sysvol/admin. When I put the MetaRepository.zpkg file there, the subsequent steps mentioned in the tread above worked to install the packages.
I can not find the directory / i-data / sysvol / admin, can you help me?
Thank you0 -
I have found /i-data/sysvol/admin folder, but it does not contain "zy-pkgs" folder. If I create that manually, and copy MetaRepository.zpkg over there, and press "Retrieve List from Internet", then I still see the official packages offered by Zyxel. It does not pick up the custom pkg.
Any idea?
UPDATE: with SSH client I have found a "zy-pkgs" folder under /i-data/304e394d/.system/zy-pkgs. That folder seemed to be promising, because it contains the already downloaded zpkg for ZyxelCloudAgent. So I have copied the zpkg package here, pressed "Retrieve List from Internet", but the package still not showing up.
I have about the same issue as Tipcsi.
I've added MetaRepository.zpkg to /i-data/sysvol/admin/zy-pkgs but when I try to retrieve the list it just refreshes the standard packages.0
- 394 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 907 Nebula FAQ
- 415 Security FAQ
- 236 Switch FAQ
- 206 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 138 Service & License FAQ
- 73 About Community
- 62 Security Highlight
