Zyxel Multy X - Bought set with 2, need one more
torholm
torholm Posts: 2 image  Freshman Member
edited December 2017 in Multy WiFi System
Hi, is it possible to buy only one of the Multy X Tri-Band AC3000? I have delivered to a customer the set with 2 and now the customer need one more to get the desired WLAN coverage.
I cannot find single one sold at any of our suplyers.
Best regards
Tor
#MultyX_December
Best Answers
  • Dardan
    Dardan Posts: 6 image  Freshman Member
    Hi Tor,
    At the moment only two devices can be connected. A 3rd device is currently not supported - maybe later.
    BR,
    Dardan
  • Zyxel_Kelly
    Zyxel_Kelly Posts: 40 image  Freshman Member
    @torholm
    Thank you for your interests!
    We expect to start selling single node Multy in January 2018 in Norway.
    It will be available in Komplett.no :)
  • Dardan
    Hi Tor,
    BR,
    Dardan
  • torholm
    That would have been nice to know before buiyng the set, as I was told that it should be easy to add another one. I suggest that this information is presented clearly somewhere relevant. Like the datasheet for example........
    Thank you for the answer anyway.
    Tor
  • Dardan
    According to the user guide more than 2 devices can be connected (Page 4).
    ftp://ftp.zyxel.com/Multy_X_(WSQ50)/user_guide/Multy X (WSQ50)_V1.0.0 ed1.pdf
    But I can't verify that. Maybe @Zyxel_Support can give us the answer.
    BR,
    Dardan
  • Zyxel_Kelly
    @torholm
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    Currently, Multy X is supported 3 units in one star topology.
