NAS326 - Raid Basic - Read disk removed from device
kubiak
Hi everyone this is my first post to this forum...
I've got a question that will -hopefully- require a quick and easy answer.
I am thinking of buying Zyxel NAS326 for using it as a longterm backup and repository solution.
It will be switched off and unplugged most of the time except for when i will be updating my longterm backup.
In fact i will be using both disks for storing exactly the same data in each one (something like RAID1 without implementing it) .
Why not use RAID1? Because i want to be able to read my data even if the NAS326 fails as a device.
In other words i want -at any time- to be able to read the data on a disk removed from a NAS326 device when i connect it to an ext4 read capable pc either directly or using an external usb case.
So i wanted to ask anyone who might know, is BASIC Raid* suitable for what i want?
Rephrasing my question: If i configure 2 disks as BASIC Raid in a NAS326 will i be able to read their data if i remove them from the NAS326 and plug both of them or either of them to a pc capable of reading ext4?
Thanks in advance even for taking the time to read my message.
#NAS_December
#NAS_December
@kubiak
Yes, if you configure the HDD as Basic, then you can access data by removing from NAS326 to Linux PC.
For RAID 1 part, Zyxel has KB to teach user to mount RAID 1 volume to save/recover data in Linux, here you are: http://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=013308&lang=EN
Thank you ljnrsi, i guess there is no reason not to proceed with purchasing the NAS326 for the intended usage then...
The KB article is very interesting too...
Welcome in Zyxel NAS user :-)0
Thank you Fredzoul1 : - )
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
