To Bridge or not to Bridge?
elcapito
Hi!
On my brand new Multy X setup, I have both tried bridged and non-bridged connection to my modem. In bridged mode I lose some functionality. So far, I cannot see any performance differences between the two setups! I understand the difference between the two....but is it necessary to choose bridged mode, even though you have an "upper" router?
#MultyX_December
#MultyX_December
I think it is depend on your usage.Bridge mode of Multy X just like Switch, but it has wireless feature.If Multy X as router mode and you also have a router which connected before Multy X.It will happen some situation:- Two DHCP pool.- Your client devices may have a hard time communicating between two network.- Double NAT, but it does not affect WiFi performance. Some case may have the problem when play online games or use IP address assignments, port forwarding rules, and UPnP.1
- 603 USG FLEX H Series
- 481 News and Release
