Can I use the Multy X with my existing BT Homehub 5
Jwils642
Jwils642 Posts: 1  Freshman Member
edited January 2018 in Multy WiFi System
i watched the set up video which describes how you just get rid of the existing router and connect your modem directly to the multy x. I have a BT Homehub that has the modem integrated in to the router.
what are the implications of this? do I need to get a new Openreach modem?
#MultyX_December
  • Godzilla
    Godzilla Posts: 8  Freshman Member
    Multy X (1st node) has to to connect to a modem/router via an Ethernet cable to gain the access to the Internet.
    You also can refer to user guide.
