NAS326 - Download of the list failed
tropper71
I have a problem whenever I trying to load the list the fault message displayed.
Due to this fact it is impossible to use the cloud. Could you help me?
#NAS_December
#NAS_December
That is probably a network problem. Wrong configured DNS and/or gateway. The box tries to download ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz (if you have fw 5.21).
You can test if that address is reachable for the NAS in Control Panel->Network->TCPIP->Network diagnostics. Try to ping host ftp2.zyxel.com.0 -
Yes I have fw5.21 I try to ping host "ftp2.zyxel.com" successful please look at the attached picture.
The NAS326 is connected via LAN to the "Fritz Box 7490".
In that case I don't know. You'll have to dive in the logfile. Enable the ssh server in Network->Terminal.
The logfile can be found in /i-data/sysvol/.system/zy-pkgs/tmp/. If you are not comfortable with the command line, you can use WinSCP to read the log. I think in that case you'll have to substitute 'sysvol' with (one of) the directory which shows up in /i-data/0 -
It is working! :DThanks!!! I think it was only the disabled ssh server. Enabled and all is fine!
Some thinks are easy but you can`t see them :-)
Hi tropper71,
The download shall be fixed now because the FTP server has some issue during the last few days. Please see the announcement on the front page.
Hello I have simillar problem with app center list.
Please see log below:
2018-01-03 00:21:34 [ipkg][][6356]: System Volume exist, SysVolPath = /i-data/9a1828c4/.system, return 1
2018-01-03 00:21:34 [ipkg][][6356]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp download DefaultWebSite ZYPKG_INFO.tgz"
2018-01-03 00:21:34 [ipkg][download][6356]: [ipkg_op][566] cmd_name: download, argv[6]: DefaultWebSite
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_set_web_site][2127] ---> using "/etc/package_src_url" (for white box version)
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_set_web_site][2141] web site: "ftp://ftp2.zyxel.com/NAS326/zypkg/5.21"
2018-01-03 00:21:34 [ipkg][download][6356]: start [zypkg_download] with [ftp://ftp2.zyxel.com/NAS326/zypkg/5.21]-[ZYPKG_INFO.tgz]-[/tmp/ZYPKG_INFO.tgz]-[zypkglist]
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_download][327] resumeFrom: "0".
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_download] strDownloadFile: ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_download] Start to download zypkglist
2018-01-03 00:22:01 [ipkg][download][6356]: dltotal: 2259641.000000, dlnow: 1105368.000000, ultotal: 0.000000, ulnow: 0.000000, dProgress: 48.92
2018-01-03 00:22:01 [ipkg][download][6356]: [write_progress][265] strProgressFile: "/tmp/zypkglist_download.progress"
2018-01-03 00:22:04 [ipkg][download][6356]: [zypkg_download] ********* curl_result: 28
2018-01-03 00:22:04 [ipkg][download][6356]: [zypkg_download] ********* [??] curl_result: 28
2018-01-03 00:22:04 [ipkg][download][6356]: [zypkg_download] Download zypkglist TIMEOUT
2018-01-03 00:22:05 [ipkg][download][6356]: [ipkg_op][652] download result: 28
2018-01-03 00:22:06 [ipkg][][6471]: System Volume exist, SysVolPath = /i-data/9a1828c4/.system, return 1
2018-01-03 00:22:06 [ipkg][][6471]: [ipkg_op][544] ******** ipkg start as " /usr/bin/ipkg-cl -f /etc/zyxel/pkg_conf/zypkg_conf/zy-pkg.conf -t /i-data/.system/zy-pkgs/tmp list"
2018-01-03 00:22:06 [ipkg][list][6471]: [ipkg_op][807]cmd_name = list, argv[optind] = (null)
Could You help?
Best regards
drom
2018-01-03 00:21:34 [ipkg][download][6356]: [zypkg_download] Start to download zypkglist<br>2018-01-03 00:22:01 [ipkg][download][6356]: dltotal: 2259641.000000, dlnow: 1105368.000000, ultotal: 0.000000, ulnow: 0.000000, dProgress: 48.92<br><span>2018-01-03 00:22:04 [ipkg][download][6356]: [zypkg_download] Download zypkglist TIMEOUT<br></span>
Your NAS takes half a minute to download 48.92% of a 2.2MB file, which apparently is too slow. What kind of internet access do you have? How much time does it take when you download
manually?0 -
Hello. Thank You for the reply!
It takes about 1min (56s - 67s) using ftp client.
I have 100 Mbps internet connection with real 92Mbps download, 10Mbps upload and ping 9 ms (speedtest.pl).
How I can enlarge timeout this pkg?
That's not possible, I'm afraid. Bu think you can use your NAS as mirror, if you are not afraid of the command line.
Enable the FTP server and create a share which is available for anonymous login over FTP. Let's say this share is called Mirror.
Then copy the contents of ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ in this share (at least ZYPKG_INFO.tgz, and the packages you want to install)
Then login (as root) over ssh, and executeecho "ftp://localhost/Mirror" >/etc/package_src_url<br>
The NAS will use your mirror until next reboot.
It might also help to ask your provider why that server is so slow. I can download the same file in 5 seconds.0 -
Hello. Thanks for new idea.
At least I have done it with my mobile Internet connection.
I connected my NAS through bridge connection to my notebook. I bridged wifi tethering connection from smartfon and LAN card.
Using this solution I have got pkgs zip from server in about 20sec. It was fast enough.
Now I turn back conection to my cable router and I can install any apps.
Thank You for help!
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
