Setup options\dhcp\webpage\
General_Musa
Just got multyX in house. I have a fairly complex setup with a vairity of stuff from door controllers to alarm-systems. This is configured with static ip on an router with i use in connection to work through vpn.
THIS means that i cannot without doing serious reconfiguration use another ip-range.
question:
CAN you disable dhcp?
HOW the he** do i access the web-based configuration page(error 404)
Can both units be used with cable from the sentral router(if so, do i use WAN in both?)
Can the system be set with static ip and as pure accesspoints?
Is there any way of going deeper into wireless-settings, and setting up several networks(i obviously need an pure 2.4 ghz network for the wireless function on the robot-vacuum)
Thanks for input!
#MultyX_January
question:
Thanks for input!
#MultyX_January
Welcome to ZYXEL COMMUNITY HOME FORUM! Please see my answer as below.
- CAN you disable dhcp?You can use Bridge Mode. (To install your Multy X as Wireless Access Point in your house.)Please refer to https://homeforum.zyxel.com/discussion/621/bridge#latest- HOW the he** do i access the web-based configuration page(error 404)Multy X does not support web-based configuration page.Please refer to https://homeforum.zyxel.com/discussion/comment/1348#Comment_1348- Can both units be used with cable from the sentral router(if so, do i use WAN in both?)Multy X has not yet supported Ethernet backhaul.Please refer to https://homeforum.zyxel.com/discussion/comment/1160#Comment_1160- Can the system be set with static ip and as pure accesspoints?When Multy X is Bridge Mode, you can set the static IP for it from upper layer router.
- Is there any way of going deeper into wireless-settings, and setting up several networks(i obviously need an pure 2.4 ghz network for the wireless function on the robot-vacuum)You can disable Single WiFi Name. It will separate SSID of 2.4GHz & 5GHz .Please refer to https://homeforum.zyxel.com/discussion/comment/1318#Comment_13180
- 588 USG FLEX H Series
- 477 News and Release
