now in english....
md2018
I have not been able to connect my Zyxel NSA325 V2 to the network for some time, here a screenshot, who can help me?
excuse my english, it's done with google translator
Danke für jede Hilfe!
thanks for any help#NAS_February
Have You tried to do a reset of the NAS?
Latest FW installed?
Thank you, I will try
Unfortunately, a reset did nothing, the same error message is shown by Windows, by the way, I have the latest firmware installed, I urgently need more help! Thanks to all
The problem is that the NSA325 only supports SMB1, while (some versions of) Windows 10 dropped support for that.
https://support.microsoft.com/en-us/help/4034314/smbv1-is-not-installed-windows-10-and-windows-server-version-1709
You have 2 options (apart from ditching either Windows or your NAS). Reinstall (and re-enable) SMBv1 on Windows, or install a newer Samba on your NAS.
[HOWTO] Update samba (to 3.6.25) using Entware-ng
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
